Salta al contenuto principale
RedOctane X-Plorer Whammy Bar Replacement
Cosa ti serve
  1. RedOctane X-Plorer Whammy Bar Replacement, Rear Case: passo 1, immagine 1 di 2 RedOctane X-Plorer Whammy Bar Replacement, Rear Case: passo 1, immagine 2 di 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Whammy Bar Replacement: passo 2, immagine 1 di 3 RedOctane X-Plorer Whammy Bar Replacement: passo 2, immagine 2 di 3 RedOctane X-Plorer Whammy Bar Replacement: passo 2, immagine 3 di 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Whammy Bar Replacement: passo 3, immagine 1 di 3 RedOctane X-Plorer Whammy Bar Replacement: passo 3, immagine 2 di 3 RedOctane X-Plorer Whammy Bar Replacement: passo 3, immagine 3 di 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: passo 4, immagine 1 di 3 RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: passo 4, immagine 2 di 3 RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: passo 4, immagine 3 di 3
    • Remove the two 7mm Phillips #2 screws from the black wire retainer.
    • Pull off the black wire retainer.
  5. RedOctane X-Plorer Whammy Bar Replacement: passo 5, immagine 1 di 1
    • Reach one finger under the guitar to push the whammy bar and its attached components from the case.
  6. RedOctane X-Plorer Whammy Bar Replacement: passo 6, immagine 1 di 2 RedOctane X-Plorer Whammy Bar Replacement: passo 6, immagine 2 di 2
    • Remove both of the plastic side tabs by gently pulling them off.
  7. RedOctane X-Plorer Whammy Bar Replacement: passo 7, immagine 1 di 1
    • Remove the two plastic tabs from the whammy bar casing.
    • Keep the spring connected to the plastic tabs throughout this step.
  8. RedOctane X-Plorer Whammy Bar Replacement: passo 8, immagine 1 di 1
    • Using two hands, remove the spring from the plastic tabs.
Conclusione
Altre 6 persone hanno completato questa guida.
[deleted]
Membro da: 04/18/18
232 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 57
Tutti i Tempi: 5,104
