Introduzione
The strum bar sensor board will often wear and stop working over time due to overuse. This guide demonstrates how to replace the strum bar sensor board.
Cosa ti serve
Remove the strap by pulling it off of the mounts located on the body and neck.
Use a screwdriver to remove the four 14mm Phillips #1 screws around the perimeter of the strum bar sensor board.
Lift up on the strum bar sensor board to remove it from the case.
