Salta al contenuto principale
RedOctane X-Plorer Motherboard Replacement
Cosa ti serve
  1. RedOctane X-Plorer Motherboard Replacement, Rear Case: passo 1, immagine 1 di 2 RedOctane X-Plorer Motherboard Replacement, Rear Case: passo 1, immagine 2 di 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Motherboard Replacement: passo 2, immagine 1 di 3 RedOctane X-Plorer Motherboard Replacement: passo 2, immagine 2 di 3 RedOctane X-Plorer Motherboard Replacement: passo 2, immagine 3 di 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Motherboard Replacement: passo 3, immagine 1 di 3 RedOctane X-Plorer Motherboard Replacement: passo 3, immagine 2 di 3 RedOctane X-Plorer Motherboard Replacement: passo 3, immagine 3 di 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Motherboard Replacement, Auxiliary Port: passo 4, immagine 1 di 3 RedOctane X-Plorer Motherboard Replacement, Auxiliary Port: passo 4, immagine 2 di 3 RedOctane X-Plorer Motherboard Replacement, Auxiliary Port: passo 4, immagine 3 di 3
    • Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
    • Gently lift up on the auxiliary port to remove it from the case.
  5. RedOctane X-Plorer Motherboard Replacement, RJ-14 Connector: passo 5, immagine 1 di 3 RedOctane X-Plorer Motherboard Replacement, RJ-14 Connector: passo 5, immagine 2 di 3 RedOctane X-Plorer Motherboard Replacement, RJ-14 Connector: passo 5, immagine 3 di 3
    • Remove the two 10mm Phillips #1 screws from the RJ-14 connector board.
    • Lift the RJ-14 connector to remove it from the case.
  6. RedOctane X-Plorer Motherboard Replacement, Keys: passo 6, immagine 1 di 3 RedOctane X-Plorer Motherboard Replacement, Keys: passo 6, immagine 2 di 3 RedOctane X-Plorer Motherboard Replacement, Keys: passo 6, immagine 3 di 3
    • Use a screwdriver to remove the 10 mm Phillips #1 screws from the key sensor board.
    • Lift up on the key sensor board to remove it from the guitar neck.
    • When using the screwdriver, make sure to avoid puncturing the wires.
  7. RedOctane X-Plorer Motherboard Replacement: passo 7, immagine 1 di 1
    • Using your fingers, remove the rubber pad to expose the colored keys.
  8. RedOctane X-Plorer Motherboard Replacement: passo 8, immagine 1 di 2 RedOctane X-Plorer Motherboard Replacement: passo 8, immagine 2 di 2
    • Reach one finger under the guitar to push the key out of the casing.
    • Repeat this step for the four remaining keys.
  9. RedOctane X-Plorer Motherboard Replacement, Strum Bar Sensor Board: passo 9, immagine 1 di 3 RedOctane X-Plorer Motherboard Replacement, Strum Bar Sensor Board: passo 9, immagine 2 di 3 RedOctane X-Plorer Motherboard Replacement, Strum Bar Sensor Board: passo 9, immagine 3 di 3
    • Use a screwdriver to remove the four 14mm Phillips #1 screws around the perimeter of the strum bar sensor board.
    • Lift up on the strum bar sensor board to remove it from the case.
  10. RedOctane X-Plorer Motherboard Replacement, Whammy Bar Sensor: passo 10, immagine 1 di 3 RedOctane X-Plorer Motherboard Replacement, Whammy Bar Sensor: passo 10, immagine 2 di 3 RedOctane X-Plorer Motherboard Replacement, Whammy Bar Sensor: passo 10, immagine 3 di 3
    • Remove the two 7mm Phillips #0 screws.
    • Using your fingers, remove the black wire retainer.
  11. RedOctane X-Plorer Motherboard Replacement: passo 11, immagine 1 di 2 RedOctane X-Plorer Motherboard Replacement: passo 11, immagine 2 di 2
    • Using one hand, remove the whammy bar and its attached components from the case.
  12. RedOctane X-Plorer Motherboard Replacement: passo 12, immagine 1 di 1
    • Using two hands, remove the whammy bar sensor.
  13. RedOctane X-Plorer Motherboard Replacement, Motherboard: passo 13, immagine 1 di 3 RedOctane X-Plorer Motherboard Replacement, Motherboard: passo 13, immagine 2 di 3 RedOctane X-Plorer Motherboard Replacement, Motherboard: passo 13, immagine 3 di 3
    • Remove the four 10mm Phillips #1 screws around the perimeter of the motherboard with a screwdriver.
    • Lift the motherboard to remove it from the case.
Conclusione
Riley
Membro da: 04/18/18
649 Reputazione
7 Guide realizzate
Cal Poly, Team S17-G1, Livingston Spring 2018 Membro di Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Membri
9 Guide realizzate
Un commento
Where can I but a replacement board?
Matthew - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 42
Tutti i Tempi: 2,438
