Salta al contenuto principale
RedOctane X-Plorer Auxiliary Port Replacement
Cosa ti serve
  1. RedOctane X-Plorer Auxiliary Port Replacement, Rear Case: passo 1, immagine 1 di 2 RedOctane X-Plorer Auxiliary Port Replacement, Rear Case: passo 1, immagine 2 di 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Auxiliary Port Replacement: passo 2, immagine 1 di 3 RedOctane X-Plorer Auxiliary Port Replacement: passo 2, immagine 2 di 3 RedOctane X-Plorer Auxiliary Port Replacement: passo 2, immagine 3 di 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Auxiliary Port Replacement: passo 3, immagine 1 di 3 RedOctane X-Plorer Auxiliary Port Replacement: passo 3, immagine 2 di 3 RedOctane X-Plorer Auxiliary Port Replacement: passo 3, immagine 3 di 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: passo 4, immagine 1 di 3 RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: passo 4, immagine 2 di 3 RedOctane X-Plorer Auxiliary Port Replacement, Auxiliary Port: passo 4, immagine 3 di 3
    • Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
    • Gently lift up on the auxiliary port to remove it from the case.
Conclusione
Riley
Membro da: 04/18/18
649 Reputazione
7 Guide realizzate
Cal Poly, Team S17-G1, Livingston Spring 2018 Membro di Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Membri
9 Guide realizzate
Un commento
What does the neck have to do with this? You mention it in the intro and step 3, but I don’t get why you’d need to open up the neck at all for this repair.
Tuesday - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,146
