Salta al contenuto principale
RedMax Trimmer Carburetor Replacement
Cosa ti serve
  1. RedMax Trimmer Carburetor Replacement, Carburetor: passo 1, immagine 1 di 3 RedMax Trimmer Carburetor Replacement, Carburetor: passo 1, immagine 2 di 3 RedMax Trimmer Carburetor Replacement, Carburetor: passo 1, immagine 3 di 3
    • Locate the red knob that locks the air filter cover to the air filter housing.
    • Rotate the knob clockwise.
    • Remove the air filter cover, exposing the air filter.
  2. RedMax Trimmer Carburetor Replacement: passo 2, immagine 1 di 2 RedMax Trimmer Carburetor Replacement: passo 2, immagine 2 di 2
    • Remove the air filter by gently pulling it away from the unit.
  3. RedMax Trimmer Carburetor Replacement: passo 3, immagine 1 di 3 RedMax Trimmer Carburetor Replacement: passo 3, immagine 2 di 3 RedMax Trimmer Carburetor Replacement: passo 3, immagine 3 di 3
    • The red panel hides a second screw. In order to expose it, locate the red choke lever on the right side of the air filter housing.
    • Push the red choke lever down.
  4. RedMax Trimmer Carburetor Replacement: passo 4, immagine 1 di 3 RedMax Trimmer Carburetor Replacement: passo 4, immagine 2 di 3 RedMax Trimmer Carburetor Replacement: passo 4, immagine 3 di 3
    • Be aware that there may still be gasoline in the lines.
    • Disconnect the yellow and black fuel lines from the carburetor assembly by pinching the clamp and sliding it down the tube.
    • Gently pull the yellow and black lines away from the assembly.
  5. RedMax Trimmer Carburetor Replacement: passo 5, immagine 1 di 3 RedMax Trimmer Carburetor Replacement: passo 5, immagine 2 di 3 RedMax Trimmer Carburetor Replacement: passo 5, immagine 3 di 3
    • Using the T27 screwdriver, unscrew the two 55mm screws that hold the air filter housing and carburetor to the trimmer.
    • Separate the carburetor from the trimmer and air filter housing.
  6. RedMax Trimmer Carburetor Replacement: passo 6, immagine 1 di 3 RedMax Trimmer Carburetor Replacement: passo 6, immagine 2 di 3 RedMax Trimmer Carburetor Replacement: passo 6, immagine 3 di 3
    • Unscrew the four 24 mm long screws that hold the carburetor together, using the #1 Phillips head screw driver.
    • Once the screws are removed, the rest of the carburetor should separate easily.
  7. RedMax Trimmer Carburetor Replacement: passo 7, immagine 1 di 3 RedMax Trimmer Carburetor Replacement: passo 7, immagine 2 di 3 RedMax Trimmer Carburetor Replacement: passo 7, immagine 3 di 3
    • Carefully remove the gaskets and carburetor and replace them in the same order that they were removed.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 58
Tutti i Tempi: 5,320
