Salta al contenuto principale
RazorX DLX Electric Skateboard Wheel Motor Replacement
Cosa ti serve
  1. RazorX DLX Electric Skateboard Wheel Motor Replacement, Battery: passo 1, immagine 1 di 3 RazorX DLX Electric Skateboard Wheel Motor Replacement, Battery: passo 1, immagine 2 di 3 RazorX DLX Electric Skateboard Wheel Motor Replacement, Battery: passo 1, immagine 3 di 3
    • Flip the skateboard upside down.
    • Use a 4 mm Allen key to remove the 25 mm bolt that secures the cover.
    • Push the cover forward to slide it off.
  2. RazorX DLX Electric Skateboard Wheel Motor Replacement: passo 2, immagine 1 di 1
    • Disconnect the battery and slide it out.
    • Lithium-ion batteries should not be punctured, heated or improperly disposed of.
  3. RazorX DLX Electric Skateboard Wheel Motor Replacement, Control Module: passo 3, immagine 1 di 3 RazorX DLX Electric Skateboard Wheel Motor Replacement, Control Module: passo 3, immagine 2 di 3 RazorX DLX Electric Skateboard Wheel Motor Replacement, Control Module: passo 3, immagine 3 di 3
    • Flip the skateboard back over.
    • Remove the six 22 mm bolts indicated on the top side of the skateboard with a 3 mm Allen key.
    • While holding the nut from the underside of the skateboard remove the four 32 mm bolts with the 3 mm Allen key.
    • Separate the trucks and control module from the board.
  4. RazorX DLX Electric Skateboard Wheel Motor Replacement: passo 4, immagine 1 di 3 RazorX DLX Electric Skateboard Wheel Motor Replacement: passo 4, immagine 2 di 3 RazorX DLX Electric Skateboard Wheel Motor Replacement: passo 4, immagine 3 di 3
    • Remove the four 20 mm bolts using a 4 mm Allen key, then remove the metal plate to separate the motor from the trucks.
    • Separate the wheel motor from the trucks
  5. RazorX DLX Electric Skateboard Wheel Motor Replacement: passo 5, immagine 1 di 1
    • Remove the two 15 mm Phillips #00 screws to free the motor cable.
    • Remove the two 15 mm Phillips #00 screws securing the battery cage.
    • You will still need to remove the standoffs to fully remove the battery cage.
  6. RazorX DLX Electric Skateboard Wheel Motor Replacement: passo 6, immagine 1 di 3 RazorX DLX Electric Skateboard Wheel Motor Replacement: passo 6, immagine 2 di 3 RazorX DLX Electric Skateboard Wheel Motor Replacement: passo 6, immagine 3 di 3
    • Remove the two standoffs holding the battery cage in place with an 8 mm wrench.
    • The standoffs have a nylon washer on either side of the battery cage.
    • Lift the battery cage up and out of the control module.
  7. RazorX DLX Electric Skateboard Wheel Motor Replacement: passo 7, immagine 1 di 3 RazorX DLX Electric Skateboard Wheel Motor Replacement: passo 7, immagine 2 di 3 RazorX DLX Electric Skateboard Wheel Motor Replacement: passo 7, immagine 3 di 3
    • Remove the 20 mm Phillips #0 screw.
    • Disconnect the DC connector. The DC connector can be identified as the connector with only two wires.
    • Disconnect the power button. It is a temporary switch, which can be identified by its 4-wire configuration.
    • Disconnect the Hall effect sensor. It can be identified by its 6-wire configuration.
    • A hall effect sensor is used to tell the board where the motor is in its rotation.
    • You will need to remove silicone and hot glue to remove the connectors.
  8. RazorX DLX Electric Skateboard Wheel Motor Replacement: passo 8, immagine 1 di 2 RazorX DLX Electric Skateboard Wheel Motor Replacement: passo 8, immagine 2 di 2
    • Disconnect the three green butt connectors.
    • These connectors will require a decent amount of force to pull them apart.
  9. RazorX DLX Electric Skateboard Wheel Motor Replacement: passo 9, immagine 1 di 1
    • Remove the Control Module by lifting it out of the plastic housing.
  10. RazorX DLX Electric Skateboard Wheel Motor Replacement, Wheel Motor: passo 10, immagine 1 di 2 RazorX DLX Electric Skateboard Wheel Motor Replacement, Wheel Motor: passo 10, immagine 2 di 2
    • Pop the grommet out of the plastic case.
    • Slide the cables through the grommet.
Conclusione
Cuesta, Team 20-4, Krynen Fall 2024 Membro di Cuesta, Team 20-4, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G4
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 38
