Introduzione
Use this guide to replace the wheel hub of the Razor Hovertrax 2.0.
The wheel hub is essential for moving as it serves as the motor and wheel.
Cosa ti serve
Use a #2 Philips screwdriver to remove the eight 18.5 mm screws from the bottom of the Hovertrax 2.0.
After disconnecting the battery, depending on which wheel hub needs replacing, you may need to take off the cover for the other side of the hoverboard. Using the #2 Phillips screwdriver, remove the eight 18.5 mm screws that are circled)
4 connections must be removed before we can take out the motherboard covering the screws holding in the wheel hub.
To remove the connectors, press and hold the clip/connector and gently pull up (if the connector does not want to come out, gently wiggle it side to side while pulling up)
