Salta al contenuto principale
Razor A Wheel Replacement
Cosa ti serve
  1. Razor A Wheel Replacement, Wheel: passo 1, immagine 1 di 1
    • Flip the scooter upside-down with the handlebars and brake on the ground.
  2. Razor A Wheel Replacement: passo 2, immagine 1 di 2 Razor A Wheel Replacement: passo 2, immagine 2 di 2
    • Grab two 3/16" Allen wrenches. Insert one in each screw on the sides of the wheel. Hold one screw in place while turning the other in a counter-clockwise direction, loosening the screw.
    • Once both screws are removed the wheel should be free and fall out.
    • One of the screws fits inside the other. The inner screw should be 5.6 mm in length. During reassembly, the screws can be put back in on either side.
    • During reassembly, do not over-tighten the screws, as you could strip them. They should be just tight enough to prevent the wheel from wobbling.
  3. Razor A Wheel Replacement: passo 3, immagine 1 di 2 Razor A Wheel Replacement: passo 3, immagine 2 di 2
    • When replacing a wheel, look for a metal sleeve in the center of the bearing that may be out of line. Forcing a screw through a sleeve that is out of line could ruin the wheel.
    • Remove any obstructions inside the bearing of the new wheel, and move the inner sleeve in the bearing with an Allen key so that the screws can slide into the bearing freely.
    • Put the replacement wheel into place in the scooter frame.
    • For extra security, you can add a small amount of threadlocker glue to the the bolt and tighten it just until until it doesn't fall off or lock the wheel.
Conclusione
Altre 3 persone hanno completato questa guida.
Jordyn
Membro da: 10/09/12
565 Reputazione
5 Guide realizzate
Cal Poly, Team 9-13, Amido Fall 2012 Membro di Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 13,623
