Introduzione
Is your Razer Phone's speaker blown? If so, here is the guide to replacing it.
Cosa ti serve
Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
Peel off the plastic speaker grill to reveal the screws.
Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
Remove the connector.
Using a Phillips #000 screwdriver, take out the seven 1 mm screws on the bottom panel of the device.
Altre 2 persone hanno completato questa guida.
