Introduzione
Having troubles charging your Razer Phone and need to replace the charging port? Follow this easy guide on how to do so.
Cosa ti serve
Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
Peel off the plastic speaker grill to reveal the screws.
Remove one 2.5 mm screw holding down the metal bracket connector using the Phillips #000 screwdriver.
Peel back the metallic shielding over the connector using tweezers.
Remove the metal bracket connector.
Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
I would highly recommend avoid using metal tweezers for this step.
Otherwise, be EXTREMELY careful with them when near the contacts around the ribbon cable.
With the battery still plugged in, trying to unplug the ribbon connector of the screen with a metal tool will cause shorts between the tiny contacts.
Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
Remove the connector.
Carefully use the Jimmy to wedge the battery out of the phone.
Thank you very much.
I used this guide to replace my battery for my Razer 2 phone and the front speaker grills have no screws at all. Had to access the battery from behind the phone. So apparently I have a different version of Razer 2 phone. So followed another guide and replaced the battery. Unfortunately, I had to deal with the speaker grills.
Using a Phillips #000 screwdriver, take out the seven 1 mm screws on the bottom panel of the device.
Altre 14 persone hanno completato questa guida.
10 Commenti
Search it on Amazon.c
hi how much you guys charge for the charging port thanks
Does this work with the razor 2
How much would this cost to get someone else to do this, I can't do this, I will end up having to buy a new phone for my son, and that's not a road I want to drive down, please and thank you
Interesting tutorial but I still do not know where I can buy the tools and parts to replace my charging port on my Razer Phone 2. Please help!
I’m late to the party, since it’s 2021. I’ve been having this issue suddenly with the third replacement phone from Razer (different issues each time).
I’ve found a StarTech laptop repair kit (I actually first found it by Googling “CCL phone repair” and it came up with the StarTech item), and ordered it. It looks to have the tools I need, and I do trust StarTech (I’ve already got their PC repair kit).
If you’re opening for the first time, underneath the grill there is a anti-dust mesh (I assume). I don’t know where I can get a replacement for this, since mine was caked in dust and peeling it off tore it (you can see remenants in the pics). It is self-adhesive, but I think a very fine mesh could be a suitable replacement, and superglue (probably).
The only reference I’ve found for a replacement USB-C charging port is “2305018-2 by TE Connectivity”, but I’m unsure if it’s for RP1 or RP2.
I’m going to open my phone up first and see if it’s just a “loose connection”; it’ll be a simpler process at least.
Has anyone replied on if this works with razer phone 2?
Double sided tape can be used to adhere the grills in place.
Lucano - Replica
How to make the Another adhesive??? Plz rply
My razed Phone Speaker grills can't put again Perfectly
Ferdi Pongbubun - Replica
Where can i find a Charging Connector for Razer Phone 2 to buy….becouse the only place i când find IT is in India and they only delyver to
curteanuice13 - Replica
