Introduzione
Having troubles charging your Razer Phone and need to replace the charging port? Follow this easy guide on how to do so.
Ricambi
Nessuna parte specificata.
Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
Peel off the plastic speaker grill to reveal the screws.
Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
Remove the connector.
Using a Phillips #000 screwdriver, take out the seven 1 mm screws on the bottom panel of the device.
Altre 10 persone hanno completato questa guida.
9 Commenti
Search it on Amazon.c
hi how much you guys charge for the charging port thanks
Does this work with the razor 2
