Introduzione
Is your Razer Phone having problems with the battery and you need to replace it? Follow this easy guide to replacing the battery on your phone. You'll need the #000 Phillips screw driver, the Torx head T5, the tweezers, the metal spudger and the jimmy.
Ricambi
Nessuna parte specificata.
Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
Peel off the plastic speaker grill to reveal the screws.
Grab hold of the connector on the right side of the phone (just above the battery) using the tweezers.
Remove the connector.
Altre 2 persone hanno completato questa guida.
5 Commenti
Hey tnx for this but how can i buy replacement battery? my battery lose energy so fast . 100 to 0 in 3 hours or less . :(
Where can I buy a battery and power button replacement for this phone
It would be nice to be able to find a batter or one that is compatible. Mine is bloated and while i can get to it easily enough i cannot find a replacement. Even a non oem that would work would be nice.
they dont have replacement batteries the only way is to buy a junk razer phone on ebay or a marketplace see if the battery is still functional and replace it as such ive had to do that and now my battery life is normal again
If you type rc30-0215 on AliExpress you’ll find the for the Razer Phone 1.
