Salta al contenuto principale
Razer Ouroboros Lock Switch Replacement
Cosa ti serve
  1. Razer Ouroboros Lock Switch Replacement, Left and Right Trigger Switch: passo 1, immagine 1 di 2 Razer Ouroboros Lock Switch Replacement, Left and Right Trigger Switch: passo 1, immagine 2 di 2
    • Flip the mouse over and remove the stickers on the back of the device. These stickers are hiding the screws we need to remove.
    • Locate and remove the captive screws to remove the hand rest.
  2. Razer Ouroboros Lock Switch Replacement: passo 2, immagine 1 di 2 Razer Ouroboros Lock Switch Replacement: passo 2, immagine 2 di 2
    • Locate and remove the six 4mm screws on the back of the device.
    • Slide the side panels off the back of the mouse.
  3. Razer Ouroboros Lock Switch Replacement: passo 3, immagine 1 di 2 Razer Ouroboros Lock Switch Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using your tweezers, grab the trigger switch that you want to replace, and lift it from its slot.
    • If you have your replacement switch, place it in the newly freed slot and reassemble your device.
    • Note: the top guards of this mouse can come off now that the panel screws have been removed. Make sure these stay in place when reassembling.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 3,185
