Salta al contenuto principale
Razer OSVR HDK 1.4 Screen Replacement
Cosa ti serve
  1. Razer OSVR HDK 1.4 Screen Replacement, Removing the Face Plate: passo 1, immagine 1 di 3 Razer OSVR HDK 1.4 Screen Replacement, Removing the Face Plate: passo 1, immagine 2 di 3 Razer OSVR HDK 1.4 Screen Replacement, Removing the Face Plate: passo 1, immagine 3 di 3
    • Remove both of these screws with #00 Phillips Screw Driver.
    • Turn upright and gently pull face plate forward. There's two grooves to help with this on the top part. It's a magnetic plate, does not take much effort.
    • Gently fold face plate out watching for connector between plate and main device.
  2. Razer OSVR HDK 1.4 Screen Replacement, Unscrewing the Board: passo 2, immagine 1 di 3 Razer OSVR HDK 1.4 Screen Replacement, Unscrewing the Board: passo 2, immagine 2 di 3 Razer OSVR HDK 1.4 Screen Replacement, Unscrewing the Board: passo 2, immagine 3 di 3
    • Remove the four screws holding the board in place.
    • One screw is hidden beneath the tape on mine.
    • Careful with the connector on the far right. Its cables are very small. I left it attached as it is not necessary to disconnect to get to screen.
    • Remove the two screws for the cable plate. (Note: I disconnected the cables on this picture, but the way I have it here is the easier approach.)
  3. Razer OSVR HDK 1.4 Screen Replacement, Disconnect the Board: passo 3, immagine 1 di 3 Razer OSVR HDK 1.4 Screen Replacement, Disconnect the Board: passo 3, immagine 2 di 3 Razer OSVR HDK 1.4 Screen Replacement, Disconnect the Board: passo 3, immagine 3 di 3
    • Both of these connectors slide out. I have also removed the cable holder plate from the top.
    • The two ribbon connectors on the left side flip open and the ribbon pops out. I used the spudger tool that came with my iFixIt kit.
    • To put it back together, you slide the ribbon back in until you can see about half the blue and close them back.
  4. Razer OSVR HDK 1.4 Screen Replacement, Disconnecting the Screen: passo 4, immagine 1 di 2 Razer OSVR HDK 1.4 Screen Replacement, Disconnecting the Screen: passo 4, immagine 2 di 2
    • Gently peel back the tape on the bottom right. There is a connector on the other side for the screen.
    • I have included a picture of this connector from reassembly for your information.
    • Gently separate the board from the back of the screen, careful with the screen connector and the connector on the top right if you left it attached.
  5. Razer OSVR HDK 1.4 Screen Replacement, Unscrewing the Screen: passo 5, immagine 1 di 3 Razer OSVR HDK 1.4 Screen Replacement, Unscrewing the Screen: passo 5, immagine 2 di 3 Razer OSVR HDK 1.4 Screen Replacement, Unscrewing the Screen: passo 5, immagine 3 di 3
    • Unscrew the two shallow screws and the one deep screw with the Phillips #1 bit.
    • There's a ribbon that I have marked in yellow that makes the deep screw hard to come out. I used my spudger to lift it up. Please note that the picture with the spudger is from reassembly.
  6. Razer OSVR HDK 1.4 Screen Replacement, Removing the Screen: passo 6, immagine 1 di 3 Razer OSVR HDK 1.4 Screen Replacement, Removing the Screen: passo 6, immagine 2 di 3 Razer OSVR HDK 1.4 Screen Replacement, Removing the Screen: passo 6, immagine 3 di 3
    • The screen slides right out.
    • Here is a picture of the screen and assembly. My OSVR had some small plastic/foam bits on it from when I got it originally so I blew it clean with the included blower but a DSLR mirror blower works too. It also has a couple small scratches on the "film" that they added between 1.3 and 1.4 but I did not mess with that.
    • You can access the lenses from here and finish tearing it down pretty easily.
  7. Razer OSVR HDK 1.4 Screen Replacement, Tips for reassembling the screen: passo 7, immagine 1 di 3 Razer OSVR HDK 1.4 Screen Replacement, Tips for reassembling the screen: passo 7, immagine 2 di 3 Razer OSVR HDK 1.4 Screen Replacement, Tips for reassembling the screen: passo 7, immagine 3 di 3
    • I found it easier to attach the board and connector prior to reassembling it into the mask.
    • Make sure the connector is correctly attached.
    • Tape it over and screw the four screws back in.
    • Follows the other steps in reverse to complete reassembly.
Conclusione
Tom
Membro da: 07/05/16
201 Reputazione
2 Guide realizzate
2 Commenti
Great step-by-step guide, but I would like to caution anyone attempting this to be EXTREMELY careful with the screen itself. Unlike a smartphone screen which has other glass layers bonded to it to provide rigidity and protection to the AMOLED panel. This screen does not and has about a 1mm of glass above the AMOLED layer. This panel is very easy to crack with slightest of pressure so I recommend that the panel is in place in the plastic carrier and the two metal plates that hold the panel inside the plastic carrier secured, but not too tight before trying to attach the connector the other side the PCB.
Michael Balzer - Replica
Hi, quick question. Is it possible to replace the screens with wider aftermarket OLEDs? I am wondering if one were to 3D print a bigger face plate and get hands on screens with wider resolution that one could potentially rebuild a much bigger FOV similar to the StarVR. Do you think this is something possible with HDK2 or out of reach? Also, what type of connectors do the screens use?
StevieMasters - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,469
