Salta al contenuto principale
Razer Naga Trinity LK-E5 Optical Encoder Replacement
Cosa ti serve
  1. Razer Naga Trinity LK-E5 Optical Encoder Replacement, Razer Naga Trinity Disassembly: passo 1, immagine 1 di 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement, Razer Naga Trinity Disassembly: passo 1, immagine 2 di 2
    • Remove the interchangeable side plate.
  2. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 2, immagine 1 di 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 2, immagine 2 di 2
    • Remove the mouse's feet using the opening pick.
  3. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 3, immagine 1 di 1
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 4, immagine 1 di 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 4, immagine 2 di 2
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 5, immagine 1 di 1
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 6, immagine 1 di 1
    • Remove the side housing using the opening pick.
  7. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 7, immagine 1 di 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 7, immagine 2 di 2
    • Remove the top housing LED 3-Pin connector that is near the main board.
  8. Razer Naga Trinity LK-E5 Optical Encoder Replacement, Scroll Wheel Housing: passo 8, immagine 1 di 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement, Scroll Wheel Housing: passo 8, immagine 2 di 2
    • Remove one 4mm black Phillips #000 screw from the left side of the mouse holding the scroll wheel LED controller board.
    • Then pull the LED controller board upwards and out.
  9. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 9, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Halberd Spudger
    $2.99
    • Pry and remove the scroll wheel feedback bar from its hold-down clips using the hook end of a halberd spudger.
  10. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 10, immagine 1 di 1
    $3.99
    • Remove the scroll wheel feedback bar from the scroll wheel by holding down the spring and using angled tweezers to remove it from its placement.
  11. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 11, immagine 1 di 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 11, immagine 2 di 2
    • Remove the scroll wheel optical encoder 3-pin connector from the main board by wiggling the connector upwards.
  12. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 12, immagine 1 di 3 Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 12, immagine 2 di 3 Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 12, immagine 3 di 3
    • Using the opening tool, pry the black bracket holding the scroll wheel in place backwards until the scroll wheel housing pops out.
  13. Razer Naga Trinity LK-E5 Optical Encoder Replacement, LK-E5 Optical Encoder: passo 13, immagine 1 di 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement, LK-E5 Optical Encoder: passo 13, immagine 2 di 2
    • Remove the scroll wheel from the scroll wheel housing using the opening tool.
  14. Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 14, immagine 1 di 2 Razer Naga Trinity LK-E5 Optical Encoder Replacement: passo 14, immagine 2 di 2
    • Remove the scroll wheel optical encoder from the scroll wheel.
Conclusione
1Commento della guida
Where can we buy a replacement from?
Daniel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 40
Tutti i Tempi: 2,976
