Salta al contenuto principale
Razer Naga Trinity LED Light Ribbon Cable Replacement
Cosa ti serve
  1. Razer Naga Trinity LED Light Ribbon Cable Replacement, Razer Naga Trinity Disassembly: passo 1, immagine 1 di 2 Razer Naga Trinity LED Light Ribbon Cable Replacement, Razer Naga Trinity Disassembly: passo 1, immagine 2 di 2
    • Remove the interchangeable side plate.
  2. Razer Naga Trinity LED Light Ribbon Cable Replacement: passo 2, immagine 1 di 2 Razer Naga Trinity LED Light Ribbon Cable Replacement: passo 2, immagine 2 di 2
    • Remove the mouse's feet using the opening pick.
  3. Razer Naga Trinity LED Light Ribbon Cable Replacement: passo 3, immagine 1 di 1
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Razer Naga Trinity LED Light Ribbon Cable Replacement: passo 4, immagine 1 di 2 Razer Naga Trinity LED Light Ribbon Cable Replacement: passo 4, immagine 2 di 2
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Razer Naga Trinity LED Light Ribbon Cable Replacement: passo 5, immagine 1 di 1
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Razer Naga Trinity LED Light Ribbon Cable Replacement: passo 6, immagine 1 di 1
    • Remove the side housing using the opening pick.
  7. Razer Naga Trinity LED Light Ribbon Cable Replacement: passo 7, immagine 1 di 2 Razer Naga Trinity LED Light Ribbon Cable Replacement: passo 7, immagine 2 di 2
    • Remove the top housing LED 3-Pin connector that is near the main board.
  8. Razer Naga Trinity LED Light Ribbon Cable Replacement, LED Light Ribbon Cable: passo 8, immagine 1 di 2 Razer Naga Trinity LED Light Ribbon Cable Replacement, LED Light Ribbon Cable: passo 8, immagine 2 di 2
    • Using the flat end of a spudger, unlock the ribbon cable holding the clips.
    • Remove the ribbon cable.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,516
