Salta al contenuto principale
Razer Naga Expert MMO Top Plastic Shell Replacement
Cosa ti serve
  1. Razer Naga Expert MMO Top Plastic Shell Replacement, Top Plastic Shell: passo 1, immagine 1 di 1
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
  2. Razer Naga Expert MMO Top Plastic Shell Replacement: passo 2, immagine 1 di 1
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga Expert MMO Top Plastic Shell Replacement: passo 3, immagine 1 di 1
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
  4. Razer Naga Expert MMO Top Plastic Shell Replacement: passo 4, immagine 1 di 1
    • Lightly pull the two plastic sides of the mouse to remove them.
Conclusione
Altre 5 persone hanno completato questa guida.
2 Commenti
do you know where i can get a new top body section? i have a molten that stopped left clicking on every click, i opened it up and the plastic pretty much was worn away
pipsqueak642 - Replica
i’m after the rubber adhesive for the side of this mouse if any one knows where to buy it from cheers.
mayo22 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,821
