Salta al contenuto principale
Razer Naga Epic Chroma Disassembly
Cosa ti serve
  1. Razer Naga Epic Chroma Disassembly, Razer Naga Epic Chroma Disassembly: passo 1, immagine 1 di 1
    • Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
  2. Razer Naga Epic Chroma Disassembly: passo 2, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the four screws.
  3. Razer Naga Epic Chroma Disassembly: passo 3, immagine 1 di 1
    • Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
    • When removing the chassis, carefully unplug the cord connecting to the top mouse buttons.
  4. Razer Naga Epic Chroma Disassembly: passo 4, immagine 1 di 1
    • Gently pull up on the right plate on the mouse; separating it.
    • Carefully repeat this step for the left side.
    • Be wary of the cable connecting to the twelve mouse buttons located on the left plate. This can be disconnected if needed.
Conclusione
Altre 12 persone hanno completato questa guida.
3 Commenti
where can i get new teflon tape ???
Kieran jones - Replica
This guide is excellent, to further it, you must take out another screw near the battery compartment and 2 on the inside of the compartment to completely take off the board to be able to clean the lense if you are having random mouse jumps and non responsiveness from the mouse, I did that and now it works like new after re-assembly. I used 70% alcohol with cotton swabs to thoroughly clean everything including the lens.
King Gosuto - Replica
Hi, can you please tell me where can I find a grip (right side) for my Razer Naga Epic mouse.
Ghufran Muhammad -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 162
Tutti i Tempi: 25,323
