Salta al contenuto principale
Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair
Cosa ti serve
  1. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair, Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: passo 1, immagine 1 di 3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair, Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: passo 1, immagine 2 di 3 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair, Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: passo 1, immagine 3 di 3
    • To get to the maelstrom wiring you must first pull off the plastic cover.
    • To do this roll the maelstrom over so the rubber cover on the back is facing up. The rubber pad simply peels off exposing the metal backplate.
    • Then remove the four 8.5mm screws on the back plate of the maelstrom.
  2. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: passo 2, immagine 1 di 2 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: passo 2, immagine 2 di 2
    • Once the four screws are removed, the top cover can be lifted off.
    • There is a ribbon wire connecting the volume wheel to the circuit board. This is not permanently attached, and can be plugged back in if it gets pulled out.
    • Remove the three 2mm screws from the circuit board to separate it from the back plate.
  3. Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: passo 3, immagine 1 di 2 Razer Megalodon – Virtual 7.1 Surround Sound USB Gaming Headset Maelstrom Wiring Repair: passo 3, immagine 2 di 2
    • The circuit board is now completely separate from the housing and the wires can now be inspected.
    • Peel back the tape on the wires to inspect any damage to the wires if there is any.
Conclusione
Altre 6 persone hanno completato questa guida.
4 Commenti
Well for the last step the wires I peeled the wires by burning them on a gas ranger. Worked Perfectly.
Edwin Lopez - Replica
can you provide the connection map for the cables that go prom remote root to headphones?
johnny1992black - Replica
comeon you wanna tell me you took picture of the cables from one side and the other one not this is a joke right?
muchas gracias por este articulo, es el 2020 y me a servido mucho para arreglar mis audifonos
diego.riquelme.cortes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 5,944
