Introduzione
Repairability rating 8/10. Easy for beginners, great speaker housing for modders. Overall Razer did a quite good job making this decently easy to disassemble.
Cosa ti serve
Using a flat metal "Jimmy" tool, gently work out the front metal screen and mesh.
Insert the tool vertically ~3-5mm (~1/8-1/4in), then pry gently away from the mesh screen. The screen should slowly start to come out directly vertical.
Repeat this every few cms/inches, working in a loop around the outside edge one or two times until you get the metal/mesh screen off.
On the bottom of the metal/mesh screen there are 12 protruding plastic tabs that are inserted ~2cm into the body of the speaker.
Use a Philips #2 screwdriver to remove the ten 14 mm-long screws mounting the inner frame to the body.
Use a Philips #2 screwdriver to remove the eight 14 mm-long screws holding in the two speakers.
Slip the plastic cover downward off the connector
Use metal tweezers or a tiny driver bit to press down the tab in the center of the connector.
Gently pull downward on the connector to disconnect it from the body.
Pull on each side of the inner plastic frame vertically to slide it out of the body.
Remove the 4 sticky screw covers from the bottom of the speaker
Use a Knife to cut through the sticker to reveal two more hidden screws. See image #3
Use a Philips #2 screwdriver to remove the six 10 mm-long screws holding the bottom cover in place
Use the Jimmy tool to remove the bottom cover, again working slowly around outside of the part. It should come off with little force needed.
Use a Philips #1 screwdriver to remove the four 8 mm-long screws holding in the RGB diffuser and board
Slip Jimmy tool between the light bar diffuser and PCB then lift gently upward, then remove the light bar diffuser and set aside
Gently pry the RGB board free using the jimmy tool and lift it upwards and away from the bottom.
Disconnect: Using a tool or your fingers, unplug the connector on the RGB board, then set it aside
Use a Philips #2 screwdriver to remove the two 14 mm-long screws holding in the main board.
Pull on the cable for the RGB board and move it to the side to expose the bracket
Use a Philips #2 screwdriver to remove the single 10 mm-long screw holding the USB-C bracket in place
Lift and remove plastic bracket covering USB-C Port
Slip the speaker cables from their wedged positions and remove the white polyester batting that was behind the two speakers
Firmly grasp the main board with your fingers and gently wiggle back and forth while pulling the board firmly outward.
Additionally pull at a slight angle downward and away from the buttons to help dislodge the USB-C port.
Continue this wiggling motion until you have gently worked the board out of it's place.
🎉 Complete! 🎉 Hope this guide helped you! 🤩
1Commento della guida
I am going to be repair the Razer Leviathan V2: Multi-Driver PC Gaming Soundbar with Subwoofer - THX Spatial. I hope the instructions on disassembling are not too far off the V2 X. Wish me luck. My issue involves it coming on with no sound, not connecting to the pc via usb. The Bluetooth will connect to the pc but no sound. The source button will not work. I'm sure something on the board will stand out lol. I know what I did wrong. I broke the thing. I mistaken my sons electric scooter power supply as the razer and over headed something.
