Introduzione
To replace the microphone, you will have to open the speaker portion of the headset. The microphone will then be accessible. The steps detailed in this guide will can then be applied to replace the microphone. The wires will have to be soldered when reassembling the headset.
Cosa ti serve
Use the broad edge of the plastic spudger and a lot of force to pop off the speaker from the headset.
Use the Phillips #00 screwdriver to remove all four 9mm screws.
Rotate the screwdriver counterclockwise when removing each screw.
Slide the speaker case laterally along the length of the microphone until the casing is completely detached from the headset.
Altre 6 persone hanno completato questa guida.
9 Commenti
I’ve come so far as the last picture but is it possible to post a picture of the cirquit board? as to where to solder the microphone to ( wich points ) since all my wires came unudone i cant tell i tried looking online for a schematic no luck.
is it possible to post a picture of the cirquit board with locations where components need to be soldered on to? all my connections became undone so im trying to figure out where each of them is attached i cannot find any schematic online.
Nice guide. But not very useful, since I can’t find any place to buy a new microphone. Has anyone found a place to buy a replacement?
