Salta al contenuto principale
Razer Blade Stealth 2017 Display Assembly Replacement
Cosa ti serve
  1. Razer Blade Stealth 2017 Display Assembly Replacement, Battery: passo 1, immagine 1 di 2 Razer Blade Stealth 2017 Display Assembly Replacement, Battery: passo 1, immagine 2 di 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Display Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Display Assembly Replacement: passo 3, immagine 1 di 2 Razer Blade Stealth 2017 Display Assembly Replacement: passo 3, immagine 2 di 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Display Assembly Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Display Assembly Replacement: passo 5, immagine 1 di 2 Razer Blade Stealth 2017 Display Assembly Replacement: passo 5, immagine 2 di 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Display Assembly Replacement, Display Assembly: passo 6, immagine 1 di 2 Razer Blade Stealth 2017 Display Assembly Replacement, Display Assembly: passo 6, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the six 4 mm screws securing the display assembly.
  7. Razer Blade Stealth 2017 Display Assembly Replacement: passo 7, immagine 1 di 3 Razer Blade Stealth 2017 Display Assembly Replacement: passo 7, immagine 2 di 3 Razer Blade Stealth 2017 Display Assembly Replacement: passo 7, immagine 3 di 3
    • Use the plastic spudger to remove the plastic brackets beneath the hinges.
  8. Razer Blade Stealth 2017 Display Assembly Replacement: passo 8, immagine 1 di 2 Razer Blade Stealth 2017 Display Assembly Replacement: passo 8, immagine 2 di 2
    • Remove any tape attached to the wires.
    • Use the plastic spudger to slide the connectors to the right to disconnect them.
  9. Razer Blade Stealth 2017 Display Assembly Replacement: passo 9, immagine 1 di 2 Razer Blade Stealth 2017 Display Assembly Replacement: passo 9, immagine 2 di 2
    • Use the plastic spudger to lift the connector off of the socket.
  10. Razer Blade Stealth 2017 Display Assembly Replacement: passo 10, immagine 1 di 2 Razer Blade Stealth 2017 Display Assembly Replacement: passo 10, immagine 2 di 2
    • Use your fingers to lift connectors off of their sockets.
  11. Razer Blade Stealth 2017 Display Assembly Replacement: passo 11, immagine 1 di 2 Razer Blade Stealth 2017 Display Assembly Replacement: passo 11, immagine 2 di 2
    • Lift the screen to the open position.
    • Remove the display assembly by sliding it away from the keyboard.
    • Do not force the display assembly off!
Conclusione
Kris Ritter
Membro da: 02/08/24
173 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 19
Tutti i Tempi: 394
