Salta al contenuto principale
Razer Blade Stealth 2017 Audio and USB-A Port Replacement
Cosa ti serve
  1. Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Battery: passo 1, immagine 1 di 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Battery: passo 1, immagine 2 di 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: passo 2, immagine 1 di 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: passo 3, immagine 1 di 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement: passo 3, immagine 2 di 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: passo 5, immagine 1 di 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement: passo 5, immagine 2 di 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
  6. Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Audio and USB-A Port: passo 6, immagine 1 di 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement, Audio and USB-A Port: passo 6, immagine 2 di 2
    • Use a plastic spudger to lift up the module connector.
  7. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: passo 7, immagine 1 di 2 Razer Blade Stealth 2017 Audio and USB-A Port Replacement: passo 7, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the two, 3mm screws from the USB-A and audio port module.
  8. Razer Blade Stealth 2017 Audio and USB-A Port Replacement: passo 8, immagine 1 di 1
    • Use a plastic spudger to remove the USB-A and audio port module from the chassis.
Conclusione
Cal Poly, Team S11-G3, Regan Fall 2019 Membro di Cal Poly, Team S11-G3, Regan Fall 2019
CPSU-REGAN-F19S11G3
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,798
