Salta al contenuto principale
Razer Blade Stealth 2016 Keyboard Replacement
Cosa ti serve
  1. Razer Blade Stealth 2016 Keyboard Replacement, Battery: passo 1, immagine 1 di 3 Razer Blade Stealth 2016 Keyboard Replacement, Battery: passo 1, immagine 2 di 3 Razer Blade Stealth 2016 Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Use a Torx screwdriver to remove the eight 3 mm screws on the back case.
    • Remove the rear cover by prying up lightly starting in one of the corners.
  2. Razer Blade Stealth 2016 Keyboard Replacement: passo 2, immagine 1 di 2 Razer Blade Stealth 2016 Keyboard Replacement: passo 2, immagine 2 di 2
    • Use a Phillips screwdriver to remove the six screws securing the battery.
  3. Razer Blade Stealth 2016 Keyboard Replacement: passo 3, immagine 1 di 1
    • Unplug the battery connector from the motherboard.
    • Remove the battery from the device.
  4. Razer Blade Stealth 2016 Keyboard Replacement, Motherboard: passo 4, immagine 1 di 1
    • Remove the red and black cables that are attached to the motherboard.
  5. Razer Blade Stealth 2016 Keyboard Replacement: passo 5, immagine 1 di 1
    • Remove the four 3.4 mm screws around the black square using a T4 Torx screwdriver.
    • Remove the heatsink.
  6. Razer Blade Stealth 2016 Keyboard Replacement: passo 6, immagine 1 di 1
    • Remove the 3.4 mm screws to the cooling fans using a T4 Torx screwdriver.
    • Remove the cooling fans.
  7. Razer Blade Stealth 2016 Keyboard Replacement: passo 7, immagine 1 di 3 Razer Blade Stealth 2016 Keyboard Replacement: passo 7, immagine 2 di 3 Razer Blade Stealth 2016 Keyboard Replacement: passo 7, immagine 3 di 3
    • Remove the 3.4 mm screws on the perimeter of the motherboard using a T4 Torx screwdriver.
  8. Razer Blade Stealth 2016 Keyboard Replacement: passo 8, immagine 1 di 1
    • Remove the motherboard.
  9. Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: passo 9, immagine 1 di 3 Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: passo 9, immagine 2 di 3 Razer Blade Stealth 2016 Keyboard Replacement, Keyboard: passo 9, immagine 3 di 3
    • Flip all white tabs up to unlock three ZIF connectors using the opening tool.
    • Flip all black tabs up to unlock the three ZIF connectors using the opening tool.
    • This is how the tabs look in the flipped up position.
  10. Razer Blade Stealth 2016 Keyboard Replacement: passo 10, immagine 1 di 3 Razer Blade Stealth 2016 Keyboard Replacement: passo 10, immagine 2 di 3 Razer Blade Stealth 2016 Keyboard Replacement: passo 10, immagine 3 di 3
    • Pull the cables out gently.
  11. Razer Blade Stealth 2016 Keyboard Replacement: passo 11, immagine 1 di 3 Razer Blade Stealth 2016 Keyboard Replacement: passo 11, immagine 2 di 3 Razer Blade Stealth 2016 Keyboard Replacement: passo 11, immagine 3 di 3
    • Remove fifty-five 3.4 mm keyboard screws with the T5 Torx screwdriver.
    • 5 screw locations are highlighted but locate all 55 screws and remove them.
  12. Razer Blade Stealth 2016 Keyboard Replacement: passo 12, immagine 1 di 3 Razer Blade Stealth 2016 Keyboard Replacement: passo 12, immagine 2 di 3 Razer Blade Stealth 2016 Keyboard Replacement: passo 12, immagine 3 di 3
    • Remove the keyboard from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 50
Tutti i Tempi: 871
