Salta al contenuto principale
Razer Blade Stealth 2016 Hard Drive Replacement
Cosa ti serve
  1. Razer Blade Stealth 2016 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Turn the laptop upside down!
  2. Razer Blade Stealth 2016 Hard Drive Replacement: passo 2, immagine 1 di 1
    • There are 10 screws in total, they can be found at the red circles shown in the picture!
    • NOTE : you need to use a T5 screwdriver!
  3. Razer Blade Stealth 2016 Hard Drive Replacement: passo 3, immagine 1 di 1
    • The hard drive is located under the fan on the left side as shown in the picture!
  4. Razer Blade Stealth 2016 Hard Drive Replacement: passo 4, immagine 1 di 1
    • The hard drive is located under the fan on the left side.
    • Slowly peel back the silver piece and black tape beneath it to reveal the hard drive.
  5. Razer Blade Stealth 2016 Hard Drive Replacement: passo 5, immagine 1 di 2 Razer Blade Stealth 2016 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Using a Phillips screwdriver, remove the 2.5 mm screw on the left side of the hard drive.
    • After you unscrew the hard drive, it will pop out by itself
    • The Phillips screw driver is included in the kit that was provided on step 2!
  6. Razer Blade Stealth 2016 Hard Drive Replacement: passo 6, immagine 1 di 2 Razer Blade Stealth 2016 Hard Drive Replacement: passo 6, immagine 2 di 2
    • Carefully slide the hard drive out from its slot.
Conclusione
Lindsay Grant
Membro da: 10/10/19
403 Reputazione
3 Guide realizzate
USF Tampa, Team S1-G4, Leahy Fall 2019 Membro di USF Tampa, Team S1-G4, Leahy Fall 2019
USFT-LEAHY-F19S1G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 33
Tutti i Tempi: 3,024
