Introduzione
This procedure is necessary because trackpad functionality is a core feature to any laptop. It should be noted that the root causes for trackpad problems within the Razer Blade RZ09-0130 2015 laptop are typically software related, so be sure that Windows and Razer Synapse is up-to-date before attempting to open the laptop. The bulk of this replacement comes from unscrewing the back panel using a T5 Torx screwdriver. Once the back panel is off, use a Phillips #0 screwdriver to remove the two screws holding the trackpad’s circuity.
Cosa ti serve
Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
Detach the two connectors from the motherboard by gently pulling them directly out of their ports with your fingers.
Un commento
Looking for that small ribbon cable, very hard to find, any clues?
