Salta al contenuto principale
Razer Blade RZ09-0130 2015 Trackpad Button Replacement
Cosa ti serve
  1. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Back Panel: passo 1, immagine 1 di 2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Back Panel: passo 1, immagine 2 di 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: passo 2, immagine 1 di 2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement: passo 2, immagine 2 di 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: passo 3, immagine 1 di 3 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: passo 3, immagine 2 di 3 Razer Blade RZ09-0130 2015 Trackpad Button Replacement, Trackpad Button: passo 3, immagine 3 di 3
    • Detach the two connectors from the motherboard by gently pulling them directly out of their ports with your fingers.
  4. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: passo 4, immagine 1 di 2 Razer Blade RZ09-0130 2015 Trackpad Button Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws holding the trackpad's circuit board to the chassis.
  5. Razer Blade RZ09-0130 2015 Trackpad Button Replacement: passo 5, immagine 1 di 1
    • Remove the trackpad circuit board by holding one end and gently lifting it upwards.
Conclusione
Cal Poly, Team S18-G1, White Winter 2020 Membro di Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
4 Membri
6 Guide realizzate
Un commento
Looking for that small ribbon cable, very hard to find, any clues?
serpentexotics - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,165
