Salta al contenuto principale
Razer Blade RZ09-0130 2015 Speaker Replacement
Cosa ti serve
  1. Razer Blade RZ09-0130 2015 Speaker Replacement, Back Panel: passo 1, immagine 1 di 2 Razer Blade RZ09-0130 2015 Speaker Replacement, Back Panel: passo 1, immagine 2 di 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Speaker Replacement: passo 2, immagine 1 di 2 Razer Blade RZ09-0130 2015 Speaker Replacement: passo 2, immagine 2 di 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Speaker Replacement, Speaker: passo 3, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the two 3mm screws from the right speaker.
  4. Razer Blade RZ09-0130 2015 Speaker Replacement: passo 4, immagine 1 di 2 Razer Blade RZ09-0130 2015 Speaker Replacement: passo 4, immagine 2 di 2
    • Using your fingers, gently pull on the wire connecting the speaker to the motherboard until it disconnects.
  5. Razer Blade RZ09-0130 2015 Speaker Replacement: passo 5, immagine 1 di 1
    • Pick up and remove the speaker.
  6. Razer Blade RZ09-0130 2015 Speaker Replacement: passo 6, immagine 1 di 1
    • Repeat the preceding steps to remove the second speaker.
Conclusione
Cal Poly, Team S18-G1, White Winter 2020 Membro di Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 12
Tutti i Tempi: 341
