Salta al contenuto principale
Razer Blade RZ09-0130 2015 Fan Replacement
Cosa ti serve
  1. Razer Blade RZ09-0130 2015 Fan Replacement, Back Panel: passo 1, immagine 1 di 2 Razer Blade RZ09-0130 2015 Fan Replacement, Back Panel: passo 1, immagine 2 di 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Fan Replacement: passo 2, immagine 1 di 2 Razer Blade RZ09-0130 2015 Fan Replacement: passo 2, immagine 2 di 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Fan Replacement, Fan: passo 3, immagine 1 di 2 Razer Blade RZ09-0130 2015 Fan Replacement, Fan: passo 3, immagine 2 di 2
    • Remove the three screw caps by pulling them upward with your fingers.
  4. Razer Blade RZ09-0130 2015 Fan Replacement: passo 4, immagine 1 di 1
    • Remove the three 3mm Phillips #0 screws.
  5. Razer Blade RZ09-0130 2015 Fan Replacement: passo 5, immagine 1 di 2 Razer Blade RZ09-0130 2015 Fan Replacement: passo 5, immagine 2 di 2
    • Peel back the two adhesive strips from the fan until they are removed.
  6. Razer Blade RZ09-0130 2015 Fan Replacement: passo 6, immagine 1 di 3 Razer Blade RZ09-0130 2015 Fan Replacement: passo 6, immagine 2 di 3 Razer Blade RZ09-0130 2015 Fan Replacement: passo 6, immagine 3 di 3
    • Remove the connector by pulling it away from the motherboard with your fingers.
  7. Razer Blade RZ09-0130 2015 Fan Replacement: passo 7, immagine 1 di 1
    • Holding the rounded edge of the fan, slowly lift upwards until it is removed.
  8. Razer Blade RZ09-0130 2015 Fan Replacement: passo 8, immagine 1 di 1
    • Repeat the preceding steps to remove the second fan.
Conclusione
Cal Poly, Team S18-G1, White Winter 2020 Membro di Cal Poly, Team S18-G1, White Winter 2020
CPSU-WHITE-W20S18G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 598
