Introduzione
If your Razer Blade RZ09-0130 2015 back panel is damaged and needs replacement or you need access to the laptop’s circuitry, please follow this guide. This is a crucial step if you want to replace any other component within the laptop. A T5 Torx screwdriver is the only tool required for this procedure. Do not attempt to pry off the back panel with another object as it should come off with little resistance.
Cosa ti serve
Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
