Introduzione
The fans in your laptop are important for keeping the internal components from overheating. So it's important to preform maintenance on them to keep your laptop working properly. Whether to replace the fans or just removing them to clean is up to you. The fans are also required to be removed if working on some other components in this device. The fans in this device are 7 x 7 CM.
Cosa ti serve
Using a Torx T5 screwdriver, remove the ten 1/8 inch screws securing the back cover.
Remove the back cover.
