Salta al contenuto principale
Razer Blackwidow Ultimate 2013 Key Replacement
Cosa ti serve
  1. Razer Blackwidow Ultimate 2013 Key Replacement, Key: passo 1, immagine 1 di 2 Razer Blackwidow Ultimate 2013 Key Replacement, Key: passo 1, immagine 2 di 2
    • The regular size keys only require your fingers to remove them, so gently pull them off the keyboard.
  2. Razer Blackwidow Ultimate 2013 Key Replacement: passo 2, immagine 1 di 2 Razer Blackwidow Ultimate 2013 Key Replacement: passo 2, immagine 2 di 2
    • For larger keys, such as the space bar or shift keys, the axel underneath needs to be released by gently pulling it out and away from the center of the keyboard with the metal spudger.
  3. Razer Blackwidow Ultimate 2013 Key Replacement: passo 3, immagine 1 di 1
    • Ensure the keys are in alignment with the groves on the keyboard. Press the keys into the keyboard to lock them in place. Do not apply too much force while pressing the keys into the keyboard.
Conclusione
Altre 3 persone hanno completato questa guida.
IUPUI, Team 2-3, Harley Fall 2015 Membro di IUPUI, Team 2-3, Harley Fall 2015
IUPUI-HARLEY-F15S2G3
4 Membri
4 Guide realizzate
2 Commenti
How can I buy the keys?
MRcrem RS - Replica
You described how to remove a key cover. You did not describe how to remove a key switch and whether or not replacement switches may be purchased.
Steven Oliger - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 81
Tutti i Tempi: 8,852
