Salta al contenuto principale
Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement
Cosa ti serve
  1. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement, USB Port Board: passo 1, immagine 1 di 3 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement, USB Port Board: passo 1, immagine 2 di 3 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement, USB Port Board: passo 1, immagine 3 di 3
    • Remove the four plastic covers and rubber feet from all four corners of the keyboard.
    • Remove the four screws.
    • Carefully pry around the bottom end of the keyboard and work your way around keyboard to un-clip the face.
  2. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: passo 2, immagine 1 di 2 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: passo 2, immagine 2 di 2
    • Turn the keyboard face up.
    • Remove the four screws which attach the keys.
    • Note the orientation of the white plastic cover relative to the LED at the bottom of the board.
  3. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: passo 3, immagine 1 di 1
    • Locate the USB at the top of the device.
    • Remove the two screws attaching the USB.
  4. Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: passo 4, immagine 1 di 2 Razer Blackwidow Tournament Edition Keyboard USB Port Board Replacement: passo 4, immagine 2 di 2
    • Unplug the cable connecting to the USB board.
    • Plug the new USB board into the slot.
    • Replace the screws in the USB board.
Conclusione
4 Commenti
hi, where do i get the new board from? thanks!
Doge The Best - Replica
You can easily find it on Ebay
Here's a link, i had the same issue
https://www.ebay.com/itm/272275162673htt...
iixroyal owlroyal -
Hey, you can easily Google the details on the USB board bottom left
I had the same issue
iixroyal owlroyal - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 31
Tutti i Tempi: 5,038
