Salta al contenuto principale
Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement
Cosa ti serve
  1. Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement, Rubber Feet: passo 1, immagine 1 di 2 Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement, Rubber Feet: passo 1, immagine 2 di 2
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement, Front Panel: passo 2, immagine 1 di 2 Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement, Front Panel: passo 2, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
  3. Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement, Spacebar Metal Bar: passo 3, immagine 1 di 2 Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement, Spacebar Metal Bar: passo 3, immagine 2 di 2
    • Pinch the top and bottom of the key of the metal bar that you wish to replace and gently lift.
    • Tilt the key upwards so that you may see underneath it.
  4. Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement: passo 4, immagine 1 di 2 Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement: passo 4, immagine 2 di 2
    • Using tweezers unfasten the metal bar from the key both places that they are connected.
    • Using tweezers unfasten the metal bar from the keyboard itself both places that they are connected.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 75
Tutti i Tempi: 7,064
