Strumenti
Parti
Nessuna parte specificata.
Turn the keyboard over so that it is lying flat on its face.
Use the iFixit opening tool to pry the rubber feet off the keyboard.
Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
Then use the IFixIt opening tool as a wedge between the front and back panel to pry open the front panel.
Instead, Slide the IFixIt opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
Flip the keyboard over so the keys are facing up.
Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
Pinch the top and bottom of the key of the metal bar that you wish to replace and gently lift.
Tilt the key upwards so that you may see underneath it.
Altre 2 persone hanno completato questa guida.
