Salta al contenuto principale
Razer Blackwidow Tournament Edition Chroma Back Panel Replacement
Cosa ti serve
  1. Razer Blackwidow Tournament Edition Chroma Back Panel Replacement, Rubber Feet: passo 1, immagine 1 di 2 Razer Blackwidow Tournament Edition Chroma Back Panel Replacement, Rubber Feet: passo 1, immagine 2 di 2
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer Blackwidow Tournament Edition Chroma Back Panel Replacement, Front Panel: passo 2, immagine 1 di 2 Razer Blackwidow Tournament Edition Chroma Back Panel Replacement, Front Panel: passo 2, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
  3. Razer Blackwidow Tournament Edition Chroma Back Panel Replacement, Back Panel: passo 3, immagine 1 di 2 Razer Blackwidow Tournament Edition Chroma Back Panel Replacement, Back Panel: passo 3, immagine 2 di 2
    • Use a Philips #1 Screwdriver to remove the four screws located below the keys.
    • Lift the main circuit board and flip it over, placing it on its top.
    • Be cautious of the wire connected to the USB Port Board.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 23
Tutti i Tempi: 2,371
