Salta al contenuto principale
Razer BlackWidow Elite Volume Knob Replacement
Cosa ti serve
  1. Razer BlackWidow Elite Volume Knob Replacement, The Volume Knob: passo 1, immagine 1 di 2 Razer BlackWidow Elite Volume Knob Replacement, The Volume Knob: passo 1, immagine 2 di 2
    • Before disassembling, make sure that the keyboard is unplugged.
    • Turn the keyboard over so the backside is exposed.
    • Remove the top rubber feet to reveal the hidden screws.
  2. Razer BlackWidow Elite Volume Knob Replacement: passo 2, immagine 1 di 2 Razer BlackWidow Elite Volume Knob Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove the two crews.
    • The two screws differ in size (10 mm & 6 mm), so keep track of which hole they go.
  3. Razer BlackWidow Elite Volume Knob Replacement: passo 3, immagine 1 di 3 Razer BlackWidow Elite Volume Knob Replacement: passo 3, immagine 2 di 3 Razer BlackWidow Elite Volume Knob Replacement: passo 3, immagine 3 di 3
    • Turn the keyboard back so that the keys are facing up.
    • Using a keycap remover, remove the keys hiding the screws.
    • The keycaps removed are shown in the 3rd picture.
    • The bigger keys, such as the spacebar or shift, have stabilizers. To remove them, carefully loosen the stabilizer until the keycap unhooks.
  4. Razer BlackWidow Elite Volume Knob Replacement: passo 4, immagine 1 di 2 Razer BlackWidow Elite Volume Knob Replacement: passo 4, immagine 2 di 2
    • Using Phillips #0 screwdriver, remove the 14 (8 mm) screws exposed after removing the keycaps.
  5. Razer BlackWidow Elite Volume Knob Replacement: passo 5, immagine 1 di 1
    • After the screws are removed, carefully lift the keyboard to open it up.
  6. Razer BlackWidow Elite Volume Knob Replacement: passo 6, immagine 1 di 3 Razer BlackWidow Elite Volume Knob Replacement: passo 6, immagine 2 di 3 Razer BlackWidow Elite Volume Knob Replacement: passo 6, immagine 3 di 3
    • Detach the cable from the circuit board
  7. Razer BlackWidow Elite Volume Knob Replacement: passo 7, immagine 1 di 3 Razer BlackWidow Elite Volume Knob Replacement: passo 7, immagine 2 di 3 Razer BlackWidow Elite Volume Knob Replacement: passo 7, immagine 3 di 3
    • Use a tool to remove the latch from the flex cable and carefully pull out the flex cable.
  8. Razer BlackWidow Elite Volume Knob Replacement: passo 8, immagine 1 di 2 Razer BlackWidow Elite Volume Knob Replacement: passo 8, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the two (6 mm) screws securing the volume knob.
    • After removing the screws, you can now easily pull out the volume knob.
  9. Razer BlackWidow Elite Volume Knob Replacement: passo 9, immagine 1 di 2 Razer BlackWidow Elite Volume Knob Replacement: passo 9, immagine 2 di 2
    • Using a Phillips #0 screwdriver, unscrew the 6 mm screws securing the knob to the bracket.
  10. Razer BlackWidow Elite Volume Knob Replacement: passo 10, immagine 1 di 2 Razer BlackWidow Elite Volume Knob Replacement: passo 10, immagine 2 di 2
    • After unscrewing the bracket, the button of the volume knob should come right off.
    • On the main component of the volume knob, the circuit board should be rotatable. Rotate the circuit board so that the cutout aligns with the hidden screw.
    • There should be 2 (3mm) screws. Use a Phillips #000 screwdriver to remove them.
  11. Razer BlackWidow Elite Volume Knob Replacement: passo 11, immagine 1 di 2 Razer BlackWidow Elite Volume Knob Replacement: passo 11, immagine 2 di 2
    • The circuit board should be attached to a ring component. Using your fingers, carefully separate them.
  12. Razer BlackWidow Elite Volume Knob Replacement: passo 12, immagine 1 di 3 Razer BlackWidow Elite Volume Knob Replacement: passo 12, immagine 2 di 3 Razer BlackWidow Elite Volume Knob Replacement: passo 12, immagine 3 di 3
    • After detaching the ring from the volume knob's circuit board, you can screw the ring component to the volume knob casing for easier re-assembly.
    • Align the screw holes between the two components. Using the 2 (3mm) screws from step 10, screw them together, as shown in the 2nd picture.
    • Simply align the snap-fit joints back together to reassemble the main volume knob component.
    • The snap-fit joints are highlighted in the 3rd picture.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 66
Tutti i Tempi: 478
