Salta al contenuto principale
Razer BlackWidow Chroma Lights Replacement
Cosa ti serve
  1. Razer BlackWidow Chroma Lights Replacement, Lights: passo 1, immagine 1 di 1
    • Gently pull off the four rubber tabs located on the corners of the keyboard with your fingers.
  2. Razer BlackWidow Chroma Lights Replacement: passo 2, immagine 1 di 1
    • Using a metal spudger, gently remove the plastic tabs that are covering the two screws.
  3. Razer BlackWidow Chroma Lights Replacement: passo 3, immagine 1 di 1
    • There are six 10mm screws indicated by the red markups . Remove the screws using the Phillips #0 Screwdriver.
  4. Razer BlackWidow Chroma Lights Replacement: passo 4, immagine 1 di 2 Razer BlackWidow Chroma Lights Replacement: passo 4, immagine 2 di 2
    • Using a metal spudger, begin prying off the faceplate of the keyboard. There are small tabs along the edge of the keyboard and the faceplate that must be released. There are four tabs along the front of the keyboard and two along each side.
  5. Razer BlackWidow Chroma Lights Replacement: passo 5, immagine 1 di 1
    • Using a plastic opening tool, lift the plastic covering away from the LED light.
  6. Razer BlackWidow Chroma Lights Replacement: passo 6, immagine 1 di 2 Razer BlackWidow Chroma Lights Replacement: passo 6, immagine 2 di 2
    • Using the Phillips #0 Screwdriver, remove the ten 10mm screws that are indicated by the red markers.
    • Click the link below to watch a video that will guide you through the rest of the steps on how to replace LEDs in the keyboard. This step does require soldering . How to Replace Back-light LEDs
Conclusione
Altre 3 persone hanno completato questa guida.
UW Tacoma, Team 2-6, Rose Winter 2017 Membro di UW Tacoma, Team 2-6, Rose Winter 2017
UWT-ROSE-W17S2G6
3 Membri
3 Guide realizzate
2 Commenti
Anyone know what type of LEDs are need for the replacement?
Huayu Nie - Replica
High brightness led’s, 3mm.
Carlos Eduardo Pereira Reis -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 56
Tutti i Tempi: 17,566
