Salta al contenuto principale
Razer Basilisk V3 Programmable Buttons Replacement
Cosa ti serve
  1. Razer Basilisk V3 Programmable Buttons Replacement, Skates: passo 1, immagine 1 di 1
    • Locate the highlighted white skates on the bottom of the mouse.
  2. Razer Basilisk V3 Programmable Buttons Replacement: passo 2, immagine 1 di 3 Razer Basilisk V3 Programmable Buttons Replacement: passo 2, immagine 2 di 3 Razer Basilisk V3 Programmable Buttons Replacement: passo 2, immagine 3 di 3
    • Heat the skate using a heat gun or hair dryer.
    • Using the pointy end of the spudger pry away a corner of the skate.
    • If the adhesive does not pull away easily, heat the skate more.
    • Once the corner of the skate comes free use the flat end of the spudger to peel off the rest of the skate.
    • Repeat these steps for each of the skates.
  3. Razer Basilisk V3 Programmable Buttons Replacement, Backplate: passo 3, immagine 1 di 1
    • Remove two 4.8 mm screws that were hidden under the front skates using a JIS #1 screwdriver.
    • Remove the single 4 mm screw beneath the thumb grip using a JIS #1 screwdriver.
  4. Razer Basilisk V3 Programmable Buttons Replacement: passo 4, immagine 1 di 3 Razer Basilisk V3 Programmable Buttons Replacement: passo 4, immagine 2 di 3 Razer Basilisk V3 Programmable Buttons Replacement: passo 4, immagine 3 di 3
    • Heat the label gently with a heat gun or hair dryer.
    • Once the adhesive is loosened, use a spudger to peel off the label carefully, revealing two additional screws.
    • Remove the two 4.8 mm screws using a JIS #1 screwdriver.
  5. Razer Basilisk V3 Programmable Buttons Replacement: passo 5, immagine 1 di 3 Razer Basilisk V3 Programmable Buttons Replacement: passo 5, immagine 2 di 3 Razer Basilisk V3 Programmable Buttons Replacement: passo 5, immagine 3 di 3
    • Carefully pry apart the mouse's top and bottom halves. Using the iFixit opening tool, start at one corner and work around the edge.
    • Be cautious of the clips that may break during this process.
    • Using a plastic opening tool, gently pry the connector apart by moving side to side to avoid bending the pins.
    • When reassembling, be mindful that the connector only fits one way, as shown in the pictures.
  6. Razer Basilisk V3 Programmable Buttons Replacement, Programmable Buttons: passo 6, immagine 1 di 3 Razer Basilisk V3 Programmable Buttons Replacement, Programmable Buttons: passo 6, immagine 2 di 3 Razer Basilisk V3 Programmable Buttons Replacement, Programmable Buttons: passo 6, immagine 3 di 3
    • Locate the mini module near the top portion of the mouse.
    • Use a JIS #0 screwdriver to remove the screws securing the module. Two screws measure 4 mm and the remaining two screws measue 10mm.
    • Carefully lift and remove the module from the mouse chassis.
  7. Razer Basilisk V3 Programmable Buttons Replacement: passo 7, immagine 1 di 2 Razer Basilisk V3 Programmable Buttons Replacement: passo 7, immagine 2 di 2
    • Identify SW2, SW3, and SW4 which are marked on the removed mini module.
    • Use a desoldering pump or solder wick to remove the solder from the contacts of SW14 and SW15.
    • Carefully remove the old buttons using tweezers.
    • Position the new click mechanisms for SW14 and SW15 and secure them by resoldering to the contacts.
  8. Razer Basilisk V3 Programmable Buttons Replacement: passo 8, immagine 1 di 3 Razer Basilisk V3 Programmable Buttons Replacement: passo 8, immagine 2 di 3 Razer Basilisk V3 Programmable Buttons Replacement: passo 8, immagine 3 di 3
    • Identify SW11 and SW12 which are marked on the removed mini module.
    • Remove the mini module plastic backing piece to allow for the removal of solder.
    • Always work in a well-ventilated area when handling solder to avoid inhaling fumes.
    • Desolder and remove the old through-hole buttons using similar techniques.
    • Insert the new buttons for SW11 and SW12, ensuring they are properly aligned.
    • Resolder the connections to secure the new buttons in place.
Conclusione
Reassemble the mouse by reversing the disassembly process. Ensure all components are securely fastened and the mini module is correctly positioned. Test the functionality of the newly installed buttons to confirm that they are responsive and operating as intended.
Brendin Costa
Membro da: 03/18/24
402 Reputazione
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 69
Tutti i Tempi: 874
