Salta al contenuto principale
Ray Ban Eyeglasses Lens Replacement
Cosa ti serve
  1. Ray Ban Eyeglasses Lens Replacement, Lens: passo 1, immagine 1 di 1
    • Source a pair of lenses that will fit the frames of your current glasses.
  2. Ray Ban Eyeglasses Lens Replacement: passo 2, immagine 1 di 1
    • Grip the top and bottom of the frame with both hands.
    • Do this very firmly, you dontt want to break the frame.
  3. Ray Ban Eyeglasses Lens Replacement: passo 3, immagine 1 di 1
    • Gently pull up on the top of the frame while pushing the lens out from the back.
    • When pushing back try to wiggle the lens first.
    • Be sure not to exert too much pressure on the frame or it may bend or break.
  4. Ray Ban Eyeglasses Lens Replacement: passo 4, immagine 1 di 1
    • Wipe the replacement lens clean with a damp cloth or towel.
  5. Ray Ban Eyeglasses Lens Replacement: passo 5, immagine 1 di 1
    • Insert the replacement lens starting at the nose bridge.
    • Line up the lens with the frame.
  6. Ray Ban Eyeglasses Lens Replacement: passo 6, immagine 1 di 1
    • Press the replacement lens along the perimeter until it snaps securely into place.
    • Once it's in place, nudge it around to be sure.
  7. Ray Ban Eyeglasses Lens Replacement: passo 7, immagine 1 di 1
    • Gently apply heat to the perimeter of the lens for a short period of time with a hairdryer on low.
    • Only do this for a couple of seconds as you don't want to burn or melt the frame or lens.
  8. Ray Ban Eyeglasses Lens Replacement: passo 8, immagine 1 di 1
    • You’ve got new glasses!
Conclusione
Altre 2 persone hanno completato questa guida.
Abdullah Syed
Membro da: 09/15/21
225 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 63
Tutti i Tempi: 3,272
