Salta al contenuto principale
Rapoo N1600 Cable Replacement
Cosa ti serve
  1. Rapoo N1600 Cable Replacement, Cable: passo 1, immagine 1 di 1
    • Start by turning the mouse over where the bottom is facing up.
  2. Rapoo N1600 Cable Replacement: passo 2, immagine 1 di 1
    • Remove the screw located in the hole.
  3. Rapoo N1600 Cable Replacement: passo 3, immagine 1 di 1
    • Flip the mouse over and detach the middle mouse part.
    • Keep the mouse on a flat surface.
  4. Rapoo N1600 Cable Replacement: passo 4, immagine 1 di 3 Rapoo N1600 Cable Replacement: passo 4, immagine 2 di 3 Rapoo N1600 Cable Replacement: passo 4, immagine 3 di 3
    • Use the iFixit opening tool to lift the cable connector plug slowly.
    • Use gentle pressure as pulling with force may damage the scroll wheel connector.
    • Using two fingers, slowly wiggle the connector plug out.
    • Do not pull from the wires.
  5. Rapoo N1600 Cable Replacement: passo 5, immagine 1 di 2 Rapoo N1600 Cable Replacement: passo 5, immagine 2 di 2
    • Place your index finger under the motherboard and lift your index finger so the motherboard pops up.
    • Ensure the bottom of the motherboard is held flat in your hand so the pieces don't fall out.
  6. Rapoo N1600 Cable Replacement: passo 6, immagine 1 di 2 Rapoo N1600 Cable Replacement: passo 6, immagine 2 di 2
    • Remove the old mouse cable.
    • Place the matching cross from the new mouse cable on the cross outline.
    • Keep the cable away from the scroll wheel area. Make sure the cable stays to the side.
    • Make sure the mouse sensor stays in place. If it falls out, set it back in place.
  7. Rapoo N1600 Cable Replacement: passo 7, immagine 1 di 3 Rapoo N1600 Cable Replacement: passo 7, immagine 2 di 3 Rapoo N1600 Cable Replacement: passo 7, immagine 3 di 3
    • To replace the motherboard, match the circle from the motherboard and mouse and press down.
    • It will make a clicking sound.
    • Add the mouse cable plug to the socket. Press down so it connects.
  8. Rapoo N1600 Cable Replacement: passo 8, immagine 1 di 2 Rapoo N1600 Cable Replacement: passo 8, immagine 2 di 2
    • Slide an iFixit opening pick between the top shell and middle slowly until the end. Do this for the other side as well.
  9. Rapoo N1600 Cable Replacement: passo 9, immagine 1 di 3 Rapoo N1600 Cable Replacement: passo 9, immagine 2 di 3 Rapoo N1600 Cable Replacement: passo 9, immagine 3 di 3
    • Match the middle part of the mouse with the bottom and slide it from top to bottom.
    • Once the middle part is attached, add the top shell of the mouse. Follow the pattern of the holes as they will help you.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 28
Tutti i Tempi: 397
