Salta al contenuto principale
Introduzione
This guide will show you how to remove a broken or malfunctioning pedal and replace it with a new one.
Parti
  1. First take an 8 in adjustable crescent wrench and fit it around the base of the pedal.
    • First take an 8 in adjustable crescent wrench and fit it around the base of the pedal.
  2. To unscrew the chain side pedal twist the the wrench counter  clockwise. To unscrew the pedal that is on the side away from the chain, twist the wrench clockwise.
    • To unscrew the chain side pedal twist the the wrench counter clockwise.
    • To unscrew the pedal that is on the side away from the chain, twist the wrench clockwise.
  3. Continue turning the wrench until the pedal detaches from the crank arm.
    • Continue turning the wrench until the pedal detaches from the crank arm.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 7-49, Forte Fall 2012 Membro di Cal Poly, Team 7-49, Forte Fall 2012
CPSU-FORTE-F12S7G49
5 Membri
5 Guide realizzate
Thanks for info.
lanzofano - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,275
