Salta al contenuto principale
Raleigh M20 Handlebars Replacement
Cosa ti serve
  1. Raleigh M20 Handlebars Replacement, Handlebars: passo 1, immagine 1 di 2 Raleigh M20 Handlebars Replacement, Handlebars: passo 1, immagine 2 di 2
    • Strip all the accessories from your old handlebars. (reflectors, mirrors, etc...)
    • Using a 3/8" Allen wrench, loosen the nuts that hold the brake controls and gear shifters.
  2. Raleigh M20 Handlebars Replacement: passo 2, immagine 1 di 3 Raleigh M20 Handlebars Replacement: passo 2, immagine 2 di 3 Raleigh M20 Handlebars Replacement: passo 2, immagine 3 di 3
    • Place an Allen wrench (size doesn't matter) under the bike grip.
    • Twist the grip back and forth while pulling on the Allen wrench to remove the grip.
  3. Raleigh M20 Handlebars Replacement: passo 3, immagine 1 di 2 Raleigh M20 Handlebars Replacement: passo 3, immagine 2 di 2
    • Slide off the gear shifters.
    • Slide off the brake controls.
  4. Raleigh M20 Handlebars Replacement: passo 4, immagine 1 di 3 Raleigh M20 Handlebars Replacement: passo 4, immagine 2 di 3 Raleigh M20 Handlebars Replacement: passo 4, immagine 3 di 3
    • Loosen the central nut on the faceplate that connects the bars to the steering column. If the bars are secured by a faceplate with a detachable top, loosen the nuts on the faceplate and remove.
    • Lift the handlebars from the bike frame.
    • Move the bars until they're in the correct position for your stance. Tighten the faceplate nuts with a 3/8" Allen wrench to firmly secure the handlebars in place.
    • Sit on the bike and make final adjustments to the positioning of the brakes and gears.
Conclusione
To reinstall the handlebars, complete these steps in reverse order. If there is a problem with the alignment, return to the handlebar repair guide and repeat step 4.
Jon Ribera
Membro da: 09/26/12
72 Reputazione
1 Guida realizzata
Cal Poly, Team 7-49, Forte Fall 2012 Membro di Cal Poly, Team 7-49, Forte Fall 2012
CPSU-FORTE-F12S7G49
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,098
