Salta al contenuto principale
Raleigh M20 Bicycle Rear Rack Replacement
Cosa ti serve
  1. Raleigh M20 Bicycle Rear Rack Replacement, Bicycle Rear Rack: passo 1, immagine 1 di 2 Raleigh M20 Bicycle Rear Rack Replacement, Bicycle Rear Rack: passo 1, immagine 2 di 2
    • Make sure that the bike is upright and stable.
    • With both hands, place the rear rack on the rear wheel of the bike. Take note of where the rear rack will attach on the bike.
    • Make sure that the rear rack is fitted on the bike.
  2. Raleigh M20 Bicycle Rear Rack Replacement: passo 2, immagine 1 di 3 Raleigh M20 Bicycle Rear Rack Replacement: passo 2, immagine 2 di 3 Raleigh M20 Bicycle Rear Rack Replacement: passo 2, immagine 3 di 3
    • Place a screw to attach the rear rack to the frame of the tire.
    • Tighten the screw with a philips screwdriver by turning it in a clockwise direction.
    • Repeat the steps above on the other side of the bike.
  3. Raleigh M20 Bicycle Rear Rack Replacement: passo 3, immagine 1 di 3 Raleigh M20 Bicycle Rear Rack Replacement: passo 3, immagine 2 di 3 Raleigh M20 Bicycle Rear Rack Replacement: passo 3, immagine 3 di 3
    • Place the metal holder to be even with the bar sticking out of the rear rack.
    • Line up the holes. Place a bolt to attach them together.
    • Use a philips screwdriver to tighten the bolts.
    • Do this for both sides.
  4. Raleigh M20 Bicycle Rear Rack Replacement: passo 4, immagine 1 di 2 Raleigh M20 Bicycle Rear Rack Replacement: passo 4, immagine 2 di 2
    • Make sure that the rear rack is even. If it is not, redo the previous step.
    • Locate the screws on top of the rear rack. Tighten the screws using a philips screwdriver.
    • Once the screws are tightened, you are done.
Conclusione
To detach the rear rack, follow the instructions of this guide in the reverse order.
Cal Poly, Team 7-49, Forte Fall 2012 Membro di Cal Poly, Team 7-49, Forte Fall 2012
CPSU-FORTE-F12S7G49
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 2,984
