Salta al contenuto principale
RYDIS H68 Pro Wheel Replacement
Cosa ti serve
  1. RYDIS H68 Pro Wheel  Replacement, Battery: passo 1, immagine 1 di 2 RYDIS H68 Pro Wheel  Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the vacuum over so that the wheels are facing you.
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
  2. RYDIS H68 Pro Wheel  Replacement: passo 2, immagine 1 di 1
    • Lift the battery cover up to reveal the battery.
    • Remove the battery.
  3. RYDIS H68 Pro Wheel  Replacement, Bumper: passo 3, immagine 1 di 3 RYDIS H68 Pro Wheel  Replacement, Bumper: passo 3, immagine 2 di 3 RYDIS H68 Pro Wheel  Replacement, Bumper: passo 3, immagine 3 di 3
    • Remove the eight 10 mm Phillips #1 screws.
  4. RYDIS H68 Pro Wheel  Replacement: passo 4, immagine 1 di 3 RYDIS H68 Pro Wheel  Replacement: passo 4, immagine 2 di 3 RYDIS H68 Pro Wheel  Replacement: passo 4, immagine 3 di 3
    • Hold the front bumper and pull it off.
    • It requires a lot of force to pull the bumper off.
  5. RYDIS H68 Pro Wheel  Replacement: passo 5, immagine 1 di 3 RYDIS H68 Pro Wheel  Replacement: passo 5, immagine 2 di 3 RYDIS H68 Pro Wheel  Replacement: passo 5, immagine 3 di 3
    • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
  6. RYDIS H68 Pro Wheel  Replacement, Wheel assembly: passo 6, immagine 1 di 1
    • Remove three 10mm Philips #1 screws that are securing the wheel assembly.
  7. RYDIS H68 Pro Wheel  Replacement: passo 7, immagine 1 di 2 RYDIS H68 Pro Wheel  Replacement: passo 7, immagine 2 di 2
    • Remove the 10mm Phillips #1 screw securing the spring.
    • Then undo the spring from the plastic hook to completely remove it from the wheel assembly.
  8. RYDIS H68 Pro Wheel  Replacement: passo 8, immagine 1 di 3 RYDIS H68 Pro Wheel  Replacement: passo 8, immagine 2 di 3 RYDIS H68 Pro Wheel  Replacement: passo 8, immagine 3 di 3
    • Lift up on the plastic piece to remove the entire wheel assembly.
  9. RYDIS H68 Pro Wheel  Replacement: passo 9, immagine 1 di 3 RYDIS H68 Pro Wheel  Replacement: passo 9, immagine 2 di 3 RYDIS H68 Pro Wheel  Replacement: passo 9, immagine 3 di 3
    • Remove the plastic frame by pulling outward on the two spots where it is fastened.
  10. RYDIS H68 Pro Wheel  Replacement: passo 10, immagine 1 di 2 RYDIS H68 Pro Wheel  Replacement: passo 10, immagine 2 di 2
    • Remove the four 10mm Phillips #1 screws around the edges of the cover.
  11. RYDIS H68 Pro Wheel  Replacement: passo 11, immagine 1 di 3 RYDIS H68 Pro Wheel  Replacement: passo 11, immagine 2 di 3 RYDIS H68 Pro Wheel  Replacement: passo 11, immagine 3 di 3
    • Lift up on the top cover to remove it.
    • Removing the top cover reveals the gear system consisting of three gears.
Conclusione
Shawn O'Meara
Membro da: 02/27/17
101 Reputazione
1 Guida realizzata
USFT-Lacy-S17S005G2 Membro di USFT-Lacy-S17S005G2
Repair Café
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 385
