Salta al contenuto principale
RYDIS H68 Pro Side Brush Motor Replacement
Cosa ti serve
  1. RYDIS H68 Pro Side Brush Motor Replacement, Battery: passo 1, immagine 1 di 2 RYDIS H68 Pro Side Brush Motor Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the vacuum over so that the wheels are facing you.
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
  2. RYDIS H68 Pro Side Brush Motor Replacement: passo 2, immagine 1 di 1
    • Lift the battery cover up to reveal the battery.
    • Remove the battery.
  3. RYDIS H68 Pro Side Brush Motor Replacement, Bumper: passo 3, immagine 1 di 3 RYDIS H68 Pro Side Brush Motor Replacement, Bumper: passo 3, immagine 2 di 3 RYDIS H68 Pro Side Brush Motor Replacement, Bumper: passo 3, immagine 3 di 3
    • Remove the eight 10 mm Phillips #1 screws.
  4. RYDIS H68 Pro Side Brush Motor Replacement: passo 4, immagine 1 di 3 RYDIS H68 Pro Side Brush Motor Replacement: passo 4, immagine 2 di 3 RYDIS H68 Pro Side Brush Motor Replacement: passo 4, immagine 3 di 3
    • Hold the front bumper and pull it off.
    • It requires a lot of force to pull the bumper off.
  5. RYDIS H68 Pro Side Brush Motor Replacement: passo 5, immagine 1 di 3 RYDIS H68 Pro Side Brush Motor Replacement: passo 5, immagine 2 di 3 RYDIS H68 Pro Side Brush Motor Replacement: passo 5, immagine 3 di 3
    • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
  6. RYDIS H68 Pro Side Brush Motor Replacement, Side Brush Motor: passo 6, immagine 1 di 1
    • Begin by unscrewing the 2 10mm screws using a Phillips #1 screwdriver.
    • Unlatch the latches indicated. It can be easily done with your finger.
    • Once unsecured, the covering for the sensors can easily be removed allowing access to the sensors.
    • The reason for these first few steps is to avoid damaging the signal wires for the sensor.
  7. RYDIS H68 Pro Side Brush Motor Replacement: passo 7, immagine 1 di 1
    • This step just shows you how everything looks after the previous steps were completed.
    • There are sensors on both the left and right side. This can be done for either side.
  8. RYDIS H68 Pro Side Brush Motor Replacement: passo 8, immagine 1 di 1
    • Unscrew the five 10mm screws using a Phillips #1 screwdriver.
  9. RYDIS H68 Pro Side Brush Motor Replacement: passo 9, immagine 1 di 1
    • The side brush motor can now be removed by lifting it up.
Conclusione
jude auguste
Membro da: 02/15/17
108 Reputazione
1 Guida realizzata
USFT-Lacy-S17S005G2 Membro di USFT-Lacy-S17S005G2
Local Repair Groups
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 594
