Salta al contenuto principale
ROYALAXE R68 TKL Key Switches Replacement
Cosa ti serve
  1. ROYALAXE R68 TKL Key Switches Replacement, Key Switches: passo 1, immagine 1 di 2 ROYALAXE R68 TKL Key Switches Replacement, Key Switches: passo 1, immagine 2 di 2
    • Unplug the keyboard from its power source.
  2. ROYALAXE R68 TKL Key Switches Replacement: passo 2, immagine 1 di 1
    • Remove all keycaps with the keycap puller.
    • You can line up the keycaps in order or take a picture of your keyboard to make it easier to put them back on at the end.
  3. ROYALAXE R68 TKL Key Switches Replacement: passo 3, immagine 1 di 2 ROYALAXE R68 TKL Key Switches Replacement: passo 3, immagine 2 di 2
    • Clean the keyboard using a compressed air duster and a small brush or cotton swab.
    • You can also clean your keycaps by soaking them in a bowl with water and soap for about 30 minutes.
  4. ROYALAXE R68 TKL Key Switches Replacement: passo 4, immagine 1 di 2 ROYALAXE R68 TKL Key Switches Replacement: passo 4, immagine 2 di 2
    • Remove the switches with the switch puller.
    • Make sure to clamp on the switch vertically instead of horizontally. Then gently pull it out.
    • Taking out the switch by pulling horizontally could damage the switch.
  5. ROYALAXE R68 TKL Key Switches Replacement: passo 5, immagine 1 di 3 ROYALAXE R68 TKL Key Switches Replacement: passo 5, immagine 2 di 3 ROYALAXE R68 TKL Key Switches Replacement: passo 5, immagine 3 di 3
    • Make sure the copper part of the switch faces you when you try to insert the switch.
    • Insert the key switch as straight as possible and press down gently until you hear a click.
    • If you fail to line it up, it will bend the copper part under the switch. This will permanently damage the switch.
  6. ROYALAXE R68 TKL Key Switches Replacement: passo 6, immagine 1 di 2 ROYALAXE R68 TKL Key Switches Replacement: passo 6, immagine 2 di 2
    • Place keycaps in their respective position.
    • Make sure all keys are operating well.
    • Enjoy your new switches!
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Angie
Membro da: 10/25/23
199 Reputazione
1 Guida realizzata
1Commento della guida
Hey! This was very helpful, thank you for making it! Now if we could get one that is focused on battery replacement 😆
Tom Mclaughlin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 34
Tutti i Tempi: 584
