Salta al contenuto principale
ROG Strix G15 G512LI M.2 SSD Replacement
Cosa ti serve
  1. ROG Strix G15 G512LI M.2 SSD Replacement, Removing The Cover: passo 1, immagine 1 di 1
    • Remove the screws from the compartment cover, As show in the diagram, unscrew the screws labeled "A" first. before unscrewing "B", Don't remove screw "B" from the cover.
  2. ROG Strix G15 G512LI M.2 SSD Replacement: passo 2, immagine 1 di 1
    • Remove the panel, but be careful as there are 2 cables linking the RGB light bar to the motherboard, carefully and gently detach them from the motherboard and lift the panel.
  3. ROG Strix G15 G512LI M.2 SSD Replacement, Installing The SSD: passo 3, immagine 1 di 2 ROG Strix G15 G512LI M.2 SSD Replacement, Installing The SSD: passo 3, immagine 2 di 2
    • Locate the M.2 SSD slots, the First and Third slots both support SATA and PCIe NVMe M.2 SSDs, and the second M.2 Slot only supports PCIe NVMe SSDs
    • Next, Insert the NVMe SSD, and screw the SSD into place with the retaining screws
Conclusione
June
Membro da: 09/28/21
590 Reputazione
3 Guide realizzate
2 Commenti
how to fix the light bar i have one side wont light on
fethallah - Replica
are the m.2 nvme slot PCIe 3.0x4 and are they all the same speed or type?
Yousef Suwaidan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 37
Ultimi 30 Giorni: 211
Tutti i Tempi: 7,850
