Salta al contenuto principale
RK5 PLUS VR Headset Headband Replacement
Cosa ti serve
  1. RK5 PLUS VR Headset Headband Replacement, Headband: passo 1, immagine 1 di 3 RK5 PLUS VR Headset Headband Replacement, Headband: passo 1, immagine 2 di 3 RK5 PLUS VR Headset Headband Replacement, Headband: passo 1, immagine 3 di 3
    • Place the headset right side up and facing you on a flat surface.
    • Gently detach the velcro straps from the top, left, and right sides of the headset and set them aside.
  2. RK5 PLUS VR Headset Headband Replacement: passo 2, immagine 1 di 1
    • Remove the white headband adjustment part and carefully pull it off of the three straps.
  3. RK5 PLUS VR Headset Headband Replacement: passo 3, immagine 1 di 3 RK5 PLUS VR Headset Headband Replacement: passo 3, immagine 2 di 3 RK5 PLUS VR Headset Headband Replacement: passo 3, immagine 3 di 3
    • To access the straps that need to be replaced, remove the padding around the visual lenses of the headset.
    • To do this, use your hands to detach the plastic frame between the padding and the lenses.
    • If you need help getting started, use a spudger or opening tool and undo the clips holding the plastic frame.
    • Unhook the old straps from the sides of the headset.
  4. RK5 PLUS VR Headset Headband Replacement: passo 4, immagine 1 di 3 RK5 PLUS VR Headset Headband Replacement: passo 4, immagine 2 di 3 RK5 PLUS VR Headset Headband Replacement: passo 4, immagine 3 di 3
    • Reattach the new velcro straps to each of the white hooks.
    • Make sure the straps are securely attached to the hooks before moving on to the next step.
  5. RK5 PLUS VR Headset Headband Replacement: passo 5, immagine 1 di 2 RK5 PLUS VR Headset Headband Replacement: passo 5, immagine 2 di 2
    • Reattach the plastic frame with the padded back onto the headset.
    • Make sure the padding is properly aligned and clicked into place.
  6. RK5 PLUS VR Headset Headband Replacement: passo 6, immagine 1 di 3 RK5 PLUS VR Headset Headband Replacement: passo 6, immagine 2 di 3 RK5 PLUS VR Headset Headband Replacement: passo 6, immagine 3 di 3
    • Reattach the top band into the top hook of the headset.
    • Take the other sides of the velcro straps and hook them into the white headband adjustment part.
    • Check that the straps are properly aligned and securely attached to the headband adjustment part.
  7. RK5 PLUS VR Headset Headband Replacement: passo 7, immagine 1 di 1
    • You have successfully replaced your damaged headbands for the RK5 Plus VR headset!
Conclusione
Faraaz Abdul
Membro da: 01/30/23
145 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 35
Tutti i Tempi: 566
