Salta al contenuto principale
RIDGID R860052 Direction of Rotation Selector Replacement
Cosa ti serve
  1. RIDGID R860052 Direction of Rotation Selector Replacement, Direction of Rotation Selector: passo 1, immagine 1 di 2 RIDGID R860052 Direction of Rotation Selector Replacement, Direction of Rotation Selector: passo 1, immagine 2 di 2
    • Remove the battery from the drill before you begin.
    • Use a T10 Torx screwdriver to remove the ten screws on the information label side of the drill.
    • These ten screws are 19 mm long.
  2. RIDGID R860052 Direction of Rotation Selector Replacement: passo 2, immagine 1 di 1
    • Lift off and remove the cover with the informational label.
  3. RIDGID R860052 Direction of Rotation Selector Replacement: passo 3, immagine 1 di 3 RIDGID R860052 Direction of Rotation Selector Replacement: passo 3, immagine 2 di 3 RIDGID R860052 Direction of Rotation Selector Replacement: passo 3, immagine 3 di 3
    • Lift up the switch assembly.
    • Unhook the rotation selector from the drill cover and replace with a new one.
Conclusione
Anna Wu
Membro da: 02/04/19
273 Reputazione
2 Guide realizzate
UC Davis, Team S18-G4, Lore Winter 2019 Membro di UC Davis, Team S18-G4, Lore Winter 2019
UCD-LORE-W19S18G4
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 241
